Is there a way to sort the scripts in the Dynamo Player alphabetically?
Currently my scripts appear to be sorted by oldest to newest:
Thanks in advance
Paul
Thanks in advance
Paul
You can try updating the creation dates of the DYNs using a program such as BulfFileChanger (freeware from Nirsoft) or alternatively, if the Dynamo Player folder is located on your local PC then the order should update Alphabetically without the need to re-parameter the creation date.
I know this is not ideal if you have your library on a network, I also have this order problem (could be due to my server refresh settings), I’ll repost once I figure out a work around
Is this persistent in 1.3.3? I am not seeing the same behavior.
Still finding this persistent with 1.3.4 and with 2.0. Any additional insights?
I’m still finding this issue too, albeit a little overshadowed by the real problem of speed issues having scripts and packages on a network drive.
