I set a Dyn Player file for generate Conduits’ elevations. But the output is not showing after run the Player file. Anyone has an idea to solve? Thank you very much.
Have you right clicked the watch node and selected ‘Is output’ ?
If you set Watch node as Output at it didn’t worked, try to rename Watch to some specific name
Thanks, Andriy. I change the name of node and then it works now.
