im trying to create a simple script that allowes me to make a section box around linked element , make in mind that i have the element ID , but whenever i try to search , the nodes are not compatible with each other somehow ,
the alghorithm that im thinking of is ,
getting all links > get all instances from them > filter to get the element by the id i typed > make section box around it ,
only node i started with and i cant go on is select.getdoucments and i stopped at this point .
can you please help?
i think i already made it with select.get doucments node but whats next? thats what im currently cant get , i want to get all instance elements from all links
unnecessary also not that straightforward. this might involve filtering by view dependency first, culling all element types, getting all things under model categories and etc. a bit tedious i reckon unless there’s a package to give a bit of shortcut.
besides, a free plugin named “CoinBox” does this. but if you are doing this for learning dynamo, targeting specific subset of categories would be easier since when you filter allinstances, instances from non-model categories might confuse you.
