Highlight linked element
is it still not doable? what if i only need section box to it which cannot do in UI
you can use Selection.SetReferences()
there is an example here
cool! thanks c.poupin, i managed to get linked element but how to convert that linked element to reference so it can be used in Selection.SetReferences()
tried below Python code but not working:
linkElems = UnwrapElement(IN[0])
linkInstance = UnwrapElement(IN[1])
linkReferences = List[Reference]([Reference(linkElem).CreateLinkReference(linkInstance) for linkElem in linkElems])
uidoc.Selection.SetReferences(linkReferences)
try this version
import sys
import System
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary, HashSet
#import Revit API
clr.AddReference('RevitAPI')
#import Revit APIUI namespace
import Autodesk.Revit.UI as RUI
from Autodesk.Revit.UI.Selection import *
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
def select_link_elems(lstElem):
    lst_refs = List[Reference]()
    for e in lstElem:
        lnk_doc = e.Document
        lnk_instance = next(( link for link in FilteredElementCollector(doc).OfClass(RevitLinkInstance)\
                            if link.GetLinkDocument().GetHashCode() == lnk_doc.GetHashCode()), None)
        if lnk_instance:
            ref = Reference(e).CreateLinkReference(lnk_instance)
            lst_refs.Add(ref)
    uidoc.Selection.SetReferences(lst_refs)
    return lstElem
def toList(x):
    if isinstance(x, (list, dict)) or \
            (hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
        return x
    else : return [x]
# OR
toList = lambda x : x if hasattr(x, "__iter__") and not isinstance(x, (str, System.String)) else [x]
lstelems = toList(UnwrapElement(IN[0]))
OUT = select_link_elems(lstelems)
no luck, i assume it’s version issue, i’m using Revit 2024, which version are you using? by the way, linked elements highlighted because of selecting which is not desired, or after running script which is desired.
Tested on Revit 2024 and 2026
Can you share a simple RVT file with which the process fails (as a linked file) ?
tested w/ new RVTs, works great! i need to take another look at project RVT and script, very appreciated for your help c.poupin!
edit: found a bug in my script, works great now w/ minor change, thanks again for your help c.poupin.
    lnk_instance = next((link for link in FilteredElementCollector(doc).OfClass(RevitLinkInstance)\\
    lnk_instance = UnwrapElement(IN\[1\])
is it doable to have both host elements and linked elements highlighted, currently i have to do it separated, kind of combining below 2 lines together
for host elements → uidoc.Selection.SetElementIds()
for linked elements → uidoc.Selection.SetReferences()
edit: did a test, cannot use both, means host elements also need to be converted to references and only use uidoc.Selection.SetReferences() i believe
edit: works OK now
