Dynamo package name
how to know dynamo package name by its node name
i want to know package name for node List.FilterByBoolMask
Hello @vikram3189 and welcome…List.FilterByBoolMask its a out of the box node shipped with Dynamo
so i cant find it?
what is similar type node which i can use for
you should find it if you search
thanks
thnaks bt is there any method available by use of we can find package name by node name if its not available
In addition to your question, you can check this website and search the package node name with the search bar below: Search Results for “element.location+” – Dynamo Nodes
It will list packages that contain a similar node.
In modern Dynamo when you open an old graph the workspace dependency manager, which will tell you the package and specific version thereof which was used. If you only have the name your best results will come from searching first the forum and then google.
I am going to ask the same thing.
thanks.
Simply right click on the node, click “help” and it should give you all the details.
If node note available ?
