Hi
I am trying to install the Orchid package for Revit 2022, but I am unable to install it specifically for Revit 2022. Please help us.
Thank You.
Hi
Thank You.
Orchid package support is exclusively via the author’s github, linked in this post and yours (we have an automatic link generation tool for the topic as it comes up fairly often)
Hi @jacob.small
I have downloaded the Orchid, but during installation, Revit 2022 does not appear as an available option.
I can’t directly help here as I don’t use the package and don’t control the installer, nor do I think anyone on the forum can as it is a custom tool that only the author can support. Towards that end the Orchid package has a github where you can create an issue and hopefully you’ll get the help you need from someone who can help.
I could speculate why you don’t see it. One thought is that 2022 is no longer supported (current release is 2026, previous 3 releases are 2025, 2024, and 2023 so 2022 is cut out) and so the author removed it as an option for the installation as he doesn’t support it either. Personally I think that’s a good idea if true, as continued use of Revit 2022 is a security risk for you and every other company you work with as it’s not getting security patches. All of that is pure speculation though - only by engaging the author at the previous link can confirm.
Alternatively you can look into not using Orchid and leveraging another package or method.
Appreciate the suggestion!
