Hi
i would like to know if there is a possibility to change back a renamed node in dynamo to the original default name if there is a solution for this it would be very helpful
Thank you
Hi
Thank you
There is extension called monacle will do… you can download as package from package manager.
i downloaded monocle package but i could not find how to rest nodes name to the default name.
Monocle won’t name nodes back to default at this time.
But, depending on your dynamo version you can hover over the node to see the original name and swap it back by double clicking the node title and renaming it.
Thank you very much, Jhon i selected show label and preview and now i can see the node name
really appreciated
thank you vijay for your time and for introducing Monocale
Right click and select help will also help finding the original name for now. This would be a good UX feature request though - can you create an Idea here: https://github.com/DynamoDS/DynamoWishlist/issues
Hi Jacob
Thank you for your support, sure i will add this idea it will be beneficial to have it in dynamo
Thanks again !
