after running a script my Revit no longer has a Dynamo instance that I can undo? another user from a different office is seeing the same behavior.
Revit 2018.3 - Dynamo 2.0.1.0
Try to read the known issues in the readme file… This is a known issue in dyn 2.0, along with the copy paste and other shortcuts, use rightclick
I appreciate the response. thanks jon
Searching ‘‘2.0 delete’’ gives you this as the first hit:
i dont have a problem deleting nodes…i can’t undo what Dynamo did in the revit document. there is no undo button, its grayed out.
@AdamHamilton it shouldn’t do that. Can you post your dyn file
