Undo Dynamo Action
Hello Dynamo Friends :slight_smile:
I would like to know which actions that run in a dynamo script can be undone in revit after the run.
An example: I have a dynamo script that duplicates a view. After the run i can not undo that in revit.
Can i affect that behavior by wrapping something in the script in a transaction?
Pretty shure thats a revit thing and not a dynamo thing, would be thankfull for any information regarding the undo behavior :slight_smile:
Kind regards
2022-04-05_14h03_43
If your script is realy doing something you can just go back!
KR
Andreas
Be wary though, there are 1-2 things you can’t just undo (I think deleting some items is one of these.)
Always save your Revit file BEFORE you run your script, that way if you can’t Ctrl+Z you still have your original file.
Strange, i can undo a view duplication i made in revit, but not if i do it with dynamo. Maybe it has to do with oder things in my script, i will post more details on this later.
You can use PostableCommand.Undo (‘one undo’)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import Revit APIUI namespace
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.Undo)
uiapp.PostCommand(commandId)
Should be doable unless there is an additional issue at play (ie: opening the document in the background, syncing or saving). Please post the graph so we can help.
You can roll back a transaction… I don’t know but how your script looks like:
Hi @c.poupin I want to apply two times undo though postable command. Is it possible ? if it is, then how should I proceed ? I have forced another undo python node till first one executes but the second one is not working.
Can you please tell me how to undo two times ?
#Postable Command by nathan.chapman
from Autodesk.Revit.UI import RevitCommandId
from Autodesk.Revit.UI import UIApplication
from Autodesk.Revit.UI import ExternalCommandData
RunIt = IN[0]
if RunIt ==  True:
	#uiapp.PostCommand(commandId)
	errorReport = "Success"
	errorReport = "Failed to do the action"
#Assign your output to the OUT variable
OUT = errorReport
Hi @shashank.baganeACM
the only solution I know of would be to work with Revit Events, but there are a few (if not many) precautions to take
I’ll post an example, just for the experience
I encountered another undo problem just a few days ago.
It´s a code that sets sheet parameters with param.Set().
While I can undo that in revit perfectly fine, I can not undo it when setting the parameters in dynamo or pyrevit.
It´s a really really rare case that a transaction is not allowing me to undo it later in the revit UI.
Edit: Not sure if I actually tried that with dynamo…maybe just a pyrevit problem…
def update_parameter(sheet, param, param_name, current_value, new_value):
    if WorksharingUtils.GetCheckoutStatus(doc, sheet.Id) != CheckoutStatus.OwnedByOtherUser:
        t = Transaction(doc, "Set Sheet Parameter")
        t.Start()
        try:
            # Check if new_value is a float and a whole number
            if isinstance(new_value, float) and new_value.is_integer():
                new_value = str(int(new_value))  # Convert to integer string if it's a whole number
                new_value = str(new_value)  # Otherwise, just convert to string
            param.Set(new_value)
            t.Commit()
            print("Success: {0} - {1}, the parameter value {2} was changed from {3} to {4}".format(sheet.SheetNumber, sheet.Name, param_name, current_value, new_value))
        except Exception as e:
            print("ERROR: {0} - {1} for {2} from {3} - Exception: {4}".format(sheet.SheetNumber, sheet.Name, param_name, current_value, str(e)))
            t.RollBack()
        print("ERROR: {0} - {1} is owned by another user, the parameters could not be set.".format(sheet.SheetNumber, sheet.Name))```
A workaround for several undos
undoCommand
use with caution
import sys
import re
import System
from System import EventHandler, Uri
from Autodesk.Revit.DB.Events import DocumentChangedEventArgs
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
import  time
class RollBackForm(Form):
	def __init__(self, nbr_undo):
		self._commandId = RevitCommandId.LookupPostableCommandId(PostableCommand.Undo)
		self._app = app
		self._uiapp = uiapp
		self._counter = 0
		self._nbr_RollBack = nbr_undo
		self.InitializeComponent()
	def InitializeComponent(self):
		self._label1 = System.Windows.Forms.Label()
		self.SuspendLayout()
		self.FormClosing += self.Form1_FormClosing
		self._app.DocumentChanged += self.ModifEvent
		# label1
		self._label1.Font = System.Drawing.Font("Microsoft Sans Serif", 12, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, 0)
		self._label1.Location = System.Drawing.Point(60, 42)
		self._label1.Name = "label1"
		self._label1.Size = System.Drawing.Size(230, 63)
		self._label1.TabIndex = 0
		self._label1.Text = "Wait RollBack in Progress..."
		# Form35
		self.ClientSize = System.Drawing.Size(346, 163)
		self.Controls.Add(self._label1)
		self.Name = "RollBack"
		self.Text = "RollBack"
		self.Shown += self.Form35Shown
		self.ResumeLayout(False)
	def RollBack(self):
		self._counter += 1
		if self._counter > self._nbr_RollBack:
			self.Close()
			self._uiapp.PostCommand(self._commandId)
	def Form35Shown(self, sender, e):
		self.RollBack()
	def ModifEvent(self, sender, e):
		# prevent if unregister  event failed
		if self.Controls.Count > 0 and all(not x.IsDisposed for x in self.Controls):
			time.sleep(1)
			self.RollBack()
	def Form1_FormClosing(self, sender, e):
		print("Closing...")
		self._app.DocumentChanged -= self.ModifEvent
nbr_undo = IN[1]
RollBackForm(nbr_undo).Show()
