I am having this issue where Dynamo keeps crashing in Revit 2026, especially when searching for a node by right clicking in the workspace and typing in the search bar that pops up. This happened to me twice today, and when Dynamo crashes, Revit becomes completely not responsive. Everything on the UI becomes grayed out, and I can’t click on anything. Eventually, I have to kill Revit from the task manager and start it back up again to keep working. I am running Dynamo 3.5.2. Was wondering if anyone else is having the same issue.
Do you have the Monocle package installed? I’ve noticed that it does exactly what you are describing when I use the node Autocomplete feature (but with Civil 3D 2026).
Does the node autocomplete feature work without monocle installed? We found a bug that we are getting patched as we speak with Node AutoComplete in 3.6.0
I was blaming the Monocle package but Dynamo crashes without Monocle when using the autocomplete feature. (Dynamo 3.5 in Civil 3D 2026.1). I thought it used to work fine before using the package but I must have been mistaken. In Dynamo 3.6 Core the autocomplete feature worked without crashing, but I have not tested it with Monocle.
