Is it possible to change the black layout back to previous white layout? and every nodes are bigger than before, it makes everything stack together. I need to manually rearrange all nodes.
I hate this layout.
And am I foced to use Cpython? my old one no longer works unless I switch them to cpython!
Hi @newshunhk ,
I don’t think there is a way to revert back to the old layout, however @jacob.small created a script which moves everything a bit outward to fix this, I just can’t seem to find the forum post.
Also, you can still use IronPython in your python nodes if I’m not mistaken.
Here is the post in question: Graph Resizer for Dynamo 2.13
If you install the IronPython 2.7 package your old python nodes/packages will work still.
thanks I found that button now ![]()
