Dynamo help
Hy, please I need help
when I want to choose: LinesFromGridUVandEdge shows a warning…I tried everything :frowning:
You can see in the image…
Not quite everything :slight_smile:
The warning spells out what you need to do.
Double click on the custom node to start editing it. Find the input in a warning state in the custom node, and edit the input name to a compliant name (usually by adding a prefix, or changing the casing so the first letter is lower case). Then save the node and close it.
OMG thank you so so much, I didn’t know that because I’am still learing Dynamo and your answer saved my day from thinking whats wrong :rofl:
