What should I do?
It’s like this now
second picture is the format I want
What should be modified to make it look like a second picture?
If you want to change column to row or vice-versa the data before exporting to excel. You can always use the List.Transpose node.
-biboy
@blsalvio List.Transpose works if you have more than 1 list. In his case he has only 1 list.
Hi Kulkul,
If you check the output list (the output of the node before going to the Data.ExportExcel), it is not a [1,2,3] (1D) formatted list, it is [[1],[2],[3]] (2D). List.Transpose will work on that.
-blsalvio
My bad, I was looking at the output of the Data.ExportExcel.
I have a question. How could I set up the script to count the elements with the same especification rather than repeating it in the list?
