My Dynamo is diplaying like this (the library is bigger than normal). i don’t know why, just in dynamo for C3D, the Dynamo for Revit still normal. i’ve tried to reinstall dynamo and Civil 3D but isn’t work.
Anyone know whats happen ?
try changing your zoom level in IE to 100%.
Hi Michael, thanks for reply.
I found the UI into the folder (C:\Program Files\Autodesk\AutoCAD 2021\C3D\Dynamo\Core\UI\Themes\Modern) but I don’t know wich file I can change the zoom level.
That file is not related - did you check your zoom level in InternetExplorer?
Michael, thanks a lot… it worked, I changed my zoom level into IE.
