Dynamo Crashing at Launch
Hi There,
I’ve installed Dynamo 2.0.2 on a colleague’s PC (Windows 7 x64). Everytime we launch Dynamo through Revit (2018.3) it crashes immediately giving the following error message:
HRESULT: [0x8876086A], Module: [SharpDX.Direct3D9], ApiCode: [D3DERR_NOTAVAILABLE/NotAvailable], Message: Unknown
at SharpDX.Result.CheckError()
at SharpDX.Direct3D9.Direct3DEx.CreateDeviceEx(Int32 adapter, DeviceType deviceType, IntPtr hFocusWindow, Int32 behaviorFlags, PresentParameters presentationParametersRef, DisplayModeEx fullscreenDisplayModeRef, DeviceEx returnedDeviceInterfaceOut)
at HelixToolkit.Wpf.SharpDX.DX11ImageSource.StartD3D()
at HelixToolkit.Wpf.SharpDX.DX11ImageSource…ctor()
at HelixToolkit.Wpf.SharpDX.DPFCanvas.StartD3D()
at HelixToolkit.Wpf.SharpDX.DPFCanvas.RenderTechniquesManagerPropertyChanged()
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at HelixToolkit.Wpf.SharpDX.Viewport3DX.RenderTechniquesManagerPropertyChanged()
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.Activate(Object item)
at System.Windows.Data.BindingExpression.AttachToContext(AttachAttempt attempt)
at System.Windows.Data.BindingExpression.MS.Internal.Data.IDataBindEngineClient.AttachToContext(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Task.Run(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Run(Object arg)
at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
I found a post from December 2016 with someone encountering the same error message however the issue was never resolved.
Wondering if anyone has found a solution to this in the 2.5 years since the previous post.
Thanks in advance.
Have you checked for Revit updates in the Autodesk Desktop App? :slight_smile:
Hi @CVestesen
No I haven’t but I’ll try this first thing in the morning when I’m back in the office.
If that doesn’t work, uninstall all things Dynamo, check the registry, and try again.
@CVestesen
No luck with that unfortunately, I’ll try a full uninstall and reinstall as suggested by @jacob.small and see how that goes…
