Dynamo crashed immediately
Hi
As soon as I open Dynamo Revit it crashes
I have no extensions or packages installed
here are the crash details:-
HRESULT: [0x8876086A], Module: [SharpDX.Direct3D9], ApiCode: [D3DERR_NOTAVAILABLE/NotAvailable], Message: Unknown
at SharpDX.Result.CheckError()
at SharpDX.Direct3D9.Direct3DEx.CreateDeviceEx(Int32 adapter, DeviceType deviceType, IntPtr hFocusWindow, Int32 behaviorFlags, PresentParameters presentationParametersRef, DisplayModeEx fullscreenDisplayModeRef, DeviceEx returnedDeviceInterfaceOut)
at HelixToolkit.Wpf.SharpDX.DX11ImageSource.StartD3D()
at HelixToolkit.Wpf.SharpDX.DX11ImageSource…ctor()
at HelixToolkit.Wpf.SharpDX.DPFCanvas.StartD3D()
at HelixToolkit.Wpf.SharpDX.DPFCanvas.RenderTechniquesManagerPropertyChanged()
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at HelixToolkit.Wpf.SharpDX.Viewport3DX.RenderTechniquesManagerPropertyChanged()
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.Activate(Object item)
at System.Windows.Data.BindingExpression.AttachToContext(AttachAttempt attempt)
at System.Windows.Data.BindingExpression.MS.Internal.Data.IDataBindEngineClient.AttachToContext(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Task.Run(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Run(Object arg)
at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
OS: Microsoft Windows NT 6.3.9600.0
CLR: 4.0.30319.42000
Dynamo: 2.3.0.5885
Hi @hend_gamal please install https://www.microsoft.com/en-us/download/details.aspx?id=8109
I installed it, it didn’t work also
Hello
To be confirmed but the latest Revit 2020 hotfix seems to correct the problem (I have not had this error since this update and a restart of the computer)
Will try it, thanks.
