Dynamo Core Revit 2018
Hi guys am struggling to download the dynamo core library I have gone into my c drive and looked into the dynamo folder and see what the issue is but I am not sure what do.
Two questions:
  1. What version of Revit 2018 are you using? Update to 2018.3 if not current.
  2. Have you tried removing all add-ins? The error message notes it’s likely an add-in or package. Removing all add-ins is the best place to start troubleshooting as a result.
Hi Jacob
I am using 2017 Revit and 2018.3
I have removed everything and redownloaded it and it still gave me the same issue
Hi @Kulkul you have dealt with this issue for me before can you help me again
@s.rooble Try uninstalling NBS Addin if your using see if that helps.
Thank you so much @Kulkul you’ve once again helped me sort this issue out, I can now continue to download all of the new dynamo packages out there, appreciate your help :slight_smile:
