Hi, good afternoon,
I have this problem, and I don’t understand why. Can somebody help me.
thank you so much.
HI
CHECK
Can you show the nodes that you use for inputs?
And there are no issue with units or text styles?
What’s in the error message? Can you hover over the warning sign and take a screenshot.
The string you are using for the layer has some special characters in it that may be causing the issue. Remove the [ the ] and the ; and see if that resolves the problem.
