Is there a way I can bypass this error and write to this parameter. It currenlty gives me a “Read Only” error .
HELP_|690x391
Can’t see the image.
As 3Pinter states, you’ve not uploaded the image.
But most times you need to access the root of the information (like a family) in order to change “read only” parameters.
The error says it all you can’t write values to “Read-Only” Parameter".
Yes I noticed.
And I was wondering if there’s anything that could be done about this limitation!
Have you looked at this:
He is not looking to change type of Text Notes. He is trying to write parameter values to it which is not possible.
