Hi Guys, I am a beginner at using Dynamo. I am trying to write from an Excel sheet to component parameters in Revit. However, I am constantly getting a warning, what am I doing wrong?
Thank you in advance!
Welcome to the community
So the simple answer to your question is that to set a Type Parameter, you need to input a value which is a Type.
A node such as this might work?
You can input a text (‘String’) value which you read from Excel, the node will then select a Type (you will need the family name as well) to input as your parameter value.
I also find this node quite useful for establishing what data types I am getting from nodes…
I suspect you may get follow-on errors, as you are using quite a complex arrangement, which is simultaneously writing to and reading from a single excel.
I would recommend that you simplify your graph, just try and do 1 thing, with 1 element. If that works, incrementally increase the complexity. It makes it easier to see what the problems are
Hopefully that helps, best of luck!
Mark
Why did you add it to the list in the first place?
Also why not use BIM One for exporting to excel?
Thank you so much for your help, it solved all my concerns.
Best regards
