Dynamo bridge modelling , Dynabridge, segments between the grids are missing
hi again,
I have been trying to model a bridge using dynabridge package for dynamo. I have tried with custom adaptive families. but the problem is that some segments between the gridlines are missing. and the right web is on left side. After checking the rot x, y angles I found out that they were, for the first segment, around 5 and for other segments were around 175.
it would be great if anyone helps.
Hello Kamble:
Try it with this script with beams worksTUNNEL.dyn (11.0 KB)
Hi Javier,
thanx for the script. it worked perfectly. thank you again
