Dynamo auto backup file
I did not found a topic for feedback about auto backup so I hope its fine to create a topic for it.
Dynamo creates a backup file for any unsaved file under %appdata%\Dynamo\Dynamo Revit\backup with the filename of backup.DYN
There are two problem with how this works:
  1. the file name is very generic and after crashing dynamo you can easily overwrite it by opening dynamo again. The file name should include a session ID or similar
  2. when you open two dynamo instances in two separate revit sessions, one of your dynamo will not have a backup as there is already a backup.DYN file locked by another session. Having a uniquie filename would resolve this as well
i often do 5-10 nodes before saving my file just to see if something i want is feasible and in some cases I lose this. Not a big deal but if I can get my 5 minutes back that’s already a win
Hello @daninet - These are very fair call-outs and we’re taking a look internally now to ensure they don’t cause downstream issues if we implement them. If they don’t, we’ll be putting it on the backlog to implement :slight_smile:
