Hi all,
Just wondering if there would be any way that I could set a periodic ‘save as’ for the Dynamo file (.dyn), as my script usually collapses, losing the work I haven´t saved since the last time.
Any help is more than appreciated.
Best Regards,
CO
dynamo does an auto backup already, if you click here it will take you to this directory and you will see the files it saves automatically.
Hi John,
Many thanks for the quick response.
Is it possible to know how often it is currently backup? and setting this current period?
Thanks again.
Best Regards,
CO
Yep! DynamoSettings.xml has this information. (stored in milliseconds I believe)
DynamoSettings.xml
is typically in a location that looks like this: C:\Users\USERNAME\AppData\Roaming\Dynamo\Dynamo Revit\2.10\DynamoSettings.xml
You can also check on the last backup’s location by checking the console (open it with ctrl+shift+ ):
