Dynamo 2.3 NO packages - Revit 2020
Hi All,
I am using Revit 2020 for the first time, and it comes with Dynamo 2.3.
I have Dynamo 1.3 and 2.0 on Revit 2019 and it has several packages installed.
Now, when using 2.3 I don’t see any of them basically, only one - Wombat.
Does this mean of 2.3 I need to re-install all of them manually?
Cheers
you can copy paste it in the correct folder %appdata%/Dynamo/2.x/packages
dynamo package installer uses a different folder for each version of dynamo and even makes the distinction between dynamo for Revit and Dynamo Sandbox
Thank you @Jean-Marc.
Unsure on the reason but I don`t have the 2.3 folder…
Sorry I got the wrong link…
I found it now
