hi all, thanks inadvance for the help i cannot install bimorph it was working last week.
we have a series of workflows one being duplicate sheets and views, and it is now not.
thanks
How are you installing BimorphNodes?
If manually you need to unblock the Dll’s. If through the package manager, first steps would be to attempt a reinstall and also make sure you don’t have it in multiple locations which you user profile may be pointing to.
Yes in lay terms. Basically it can’t find the BimirphNodes dll or it’s blocked if it can. Try reinstalling as the simplest solution
thanks! will give it a go i think its a network sharing issue
have been trying to track this problem still no joy this is what i am getting from the console…
Exception when attempting to load package archi-lab.net from Q:\BIM\Dynamo\packages\archi-lab.net
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\archi-lab.net\bin\archilab.customization.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception when attempting to load package bimorphNodes from Q:\BIM\Dynamo\packages\bimorphNodes
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\bimorphNodes\bin\BimorphNodes.customization.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception when attempting to load package BVN from Q:\BIM\Dynamo\packages\BVN
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\BVN\bin\Package.customization.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception when attempting to load package Data-Shapes from Q:\BIM\Dynamo\packages\Data-Shapes
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\Data-Shapes\bin\DataShapesUI.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception when attempting to load package Rhynamo from Q:\BIM\Dynamo\packages\Rhynamo
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\Rhynamo\bin\ProvingGround.RhinoConnect.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
Exception when attempting to load package SpringsUI from Q:\BIM\Dynamo\packages\SpringsUI
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\BIM\Dynamo\packages\SpringsUI\bin\SpringsUI.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
DynamoPackageManager (id: FCABC211-D56B-4109-AF18-F434DFE48139) extension is added
