Thanks for your answer, I´m attaching the Revit file and Dynamo script .
I think that might be somethimg wrong with view template maybe?
RoomScheduleMultiple.rvt (356 KB)
uh, not sure if this an issue with rooms or some of the listing levels in your out put.
see below
I stumbled across this post looking for something else, here is the one that I use to automate my note block duplication. I hope it helps.
Two Dynamo release versions included.
R18_DYN-1.3.3_Schedule Script.dyn (11.9 KB) R19_DYN 2.0.1_Schedule Script.dyn (24.0 KB)
I built somthing similar a few months ago for our note schedules as well that hasnt failed us yet.
DUPLICATE SCHEDULE AND RENAME - UI.dyn (47.1 KB)
So I’m working on a similar task, trying to generate a series of equipment schedules and apply a filter based off the room number. So first I’ll thank the others before me for posting as they’ve provided much help. But I’m having issues trying to get the List of Filters applied to the New List of Schedule views. I’ve played around with the levels and I can get all of the schedules to duplicate and name themselves correctly, however applying the filter seems to fail. First, it’s not actually grabbing the Room Filed from the list. It’s just grabbing the first field (Discipline) from the list and applying the first room number from that list.
Any insight would be wonderful. I’ve attached a screen shot of the graph.
I was able to solve my own problem today. Thanks Dynamobim.com!
I found another thread with similar issue. First I was missing a Flatten node after the ScheduleView.fields node and I needed to set lacing to longest in the FilterAdd node. Here’s an updated Graph. I should mention this was done in 2.02
Hi @M.Melching
I would like to thank you for sharing your Dynamo script and costum nodes,
When i run them into my project i got some issued like:
i got the duplicated schedule named “Test Name” but the filter “waiting” didn’t get applied for this new schedule.
you can check the picture bellow:
can you check to see if the original template schedule already had the filtered applied
Hi @Wuillian_Medrano,
Thank you for your respond, and I finaly solved the probleme, and it was about the filter “name” it must be in the first line of the Field List, to allow Dynamo to change it.
this is a great help, thank you david
I have downloaded a couple of these but they do not quite do what i require
I have 2 types of schedules
First one a generic model schedule
Second one a reinforcement schedule
i need to in this project create 100 schedules of each and change the filter to an element Parameter to cull out the other 99 sets of data
and then possibly rename these schedules to suit the named element parameter
Any ideas??
