Duct/Pipe Splitting with union
I need to split duct. I got a dynamo script on this post Divide a duct .
  1. The Script separates all the ducts from the connected fittings and I need to rejoin with all the fittings
  2. In manual modeI I cannot rerun the script on other element
  3. How do i set minimum and maximum split length of the duct
I’ve made a Screencast of my Problem
Screencast Of Problem
I do not know how do I take screenshot of such long script so I uploaded file instead
Erfajo_Ductsplit.dyn (74.2 KB)
Thank you for replying Erfajo. My current level knowledge of dynamo doesn’t let me to manipulate curves/Geometry/Python/Designscript. But I believe this process could be way simplified by simply placing union at specific distance for eg.( minimum -300/maximum-1500) . Or maybe split at point command at specific distance.
  1. Select the Duct Element
  2. Get Points at specific Distance ( Minimum / Maximum)
  3. Place Union Fittings / Split at Point command at the point
Is this possible in dynamo?
Please have a look at this screencast.
I tried with Mepfitting.byPointsAndCurve .
But-
  1. Not getting Union Fittings on the 10% divided distance
  2. I need to define distance at 1400. But minimum should be 300
    Hope I’ll get some help here @erfajo , @T_Pover
Mepover_Duct_Union.dyn (6.3 KB)
Thank you for replying.
  1. I tried the solution . Maybe it was because of orchid package it is still problematic. Orchid package didn’t showed up in my dynamo ( only preliminary one showed up) . I tried to install the package and even manually copy pasted in support folder.
  2. Instead of creating new elements and joining with fitting elements isn’t there a way to simply place union fittings / split command in the ducts? I got problem in all the fittings not only Elbows.
  3. When I say minimum for example if the total duct length is 4100 mm then it would look something like this
    for( min 300 ,max 1400) ,(1400-1400-1000-300) . As Duct fabricator do not prefer to fabricate minimum than 300 in our case
Thank you for you help so far.
  1. Ducts are still not connecting with elements. I’ve made a screencast of another situation.
    Duct Union Splitting
Erfajo_Duct.Split.dyn (81.1 KB)
  1. Why is MEPFitting.ByPointsAndCurve not working for me?
After split duct, duct and fitting duct contact to each other but they are not connect.
Same problem to me. Hoping someone give any solution :frowning:
Ducts are still not joining. Even after using the latest script
I haved copied DuctJoinElements.py into C:\Program Files (x86)\IronPython 2.7\Lib. when i run dynamo, the error appears as shown below.
I’m not sure if its the best way but here are two other options.
1.
option%201
option%202
It worked. but there are still some unconnected segments as shown below
Thank you so much for your help so far.
  1. If I connect there other fittings there are still lot of Disconnections. But I can live with that I think.
  2. Can you please so me the direction on adding Min /Max intelligence
  3. And Item Length to be
    Item Length = if ( or ( Duct Height >450 , Duct Width >450) , 1420 , 1500)
Thank you very much for your help so far.
elbow.bymepcurve of me don’t work, it is empty after run, can you help me.
@Sujan As I can see @erfajo has already given you a possible solution. Try to put some efforts in working with the help you are given by yourself to become familiar with dynamo.
@Hieudang96as Your missing margins input. Please read carefully how nodes you are using work, try to see the help provided in the node you are using.
@Sujan, @Hieudang96as
Instead of firing away questions towards people that may help you, try put some efforts in solving problems first by your self. This is not a “do my job” community. The community is driven by people who offer their knowledge voluntary in their spare time. Please respect that.
Cheers!
I’m having the same problem as @Sujan. I am using dynamo 2.0.1. Do not know if @erfajo can run without error? If you do not get bugs then I think by the dynamo version.
Thank you for your help.
Hi Guys,
I complete agree with @erfajo and @Kulkul little effort will take a long way, first check the dynamo version and check you have all packages that you need to run the graph. For beginners, take a graph and follow it with small inputs and study what each node is doing. I printed the graphs and followed it manually. Once you get your head around it, you can tweak it to suit your needs. my graphs run on 1.3.2 to 2.0.0.
I have edited and it worked. @Sujan you need to edit “margin = 0” => “margin = 5” in python. But the branch is still unable to connect.
Hy @erfajo
very nice look your posting. Awesome :smiley:
I tried to follow your dynamo and download Orchid Package but my List.Clean different with you, please see pict. in below:
image This is from your post
image This from my dynamo
But the result still failed. :disappointed_relieved::disappointed_relieved:
I attached my Dyn. Files
please check friends.
Duct Splitting.dyn (23.2 KB)
@Harywijaya.2 this post i already solved. Start a new topic with all the previews and errors expanded. And also mention this post as reference.
@Kulkul okayy Sir, sorry still not understand with rules of this fourm
i’ve created new topic ^^
