Duct fittings - connector names?
If I click on duct fitting f.e. tee, elbow etc. I can see every connector diameter.
Is it possible to give name for this connectors and show them after mark?
F.e. If i click on tee I want know which connecor is inlet, outlet and branch.
Regards
@AeM_86 ,
snoop out your elements f.e. with
x.Parameters
x.Name
KR
Andreas
I try x.Parameters… and
@AeM_86 ,
for x.Parameters you need elements (familyInstances) as input.
Maybe by analyzing the flow direction with Direction property
import sys
import System
clr.AddReference("RevitAPI")
if isinstance(IN[0], list):
	fittings = UnwrapElement(IN[0])
	fittings = [UnwrapElement(IN[0])]
dict_flowDirect = dict(zip(System.Enum.GetValues(FlowDirectionType), System.Enum.GetNames(FlowDirectionType)))
print(dict_flowDirect)
out_connectors = []
out_direction = []
for fitting in fittings:
	if fitting.MEPModel is not None:
		connectors = fitting.MEPModel.ConnectorManager.Connectors
		connectors = fitting.ConnectorManager.Connectors
	out_connectors.append(connectors)
	out_direction.append([dict_flowDirect.get(conn.Direction) for conn in connectors])
OUT = out_connectors, out_direction
