Hi I’m referencing a previous topic because I would like to know more information. The topic below was solved therefore closed.
I would like to know the section nodes used in dynamo for the data set used in the example.
I have experimented with section by bounding box and section by cs min/max.
I would be grateful for any further input.
Many thanks.
sorry
I’m Not Use
any Section Node at dynamo program
I’m create
this sections in civil 3d
than I extract the points from this sections to
excel sheet
all one
section contains 51 points
I’m put the
51 points in excel at one page
Example the
F page contains 51 points for first section
And G Page
contains 51 points for next section
Now: than I’m
Import this excel to dynamo
All points
in one section it’s will appear on form section
then I connect
between this points by line and arc nodes for draw the section
في الثلاثاء، 2 أبريل 2019 في 7:16 م تمت كتابة ما يلي بواسطة DynamoCanDo via Dynamo <dynamobim@discoursemail.com>:
note:
this girder
forms it’s with super elevation and sometimes with widening
in revit I can’t
create or calculate super elevation and widening
in civil 3d
you can do it
في الجمعة، 5 أبريل 2019 في 2:20 م تمت كتابة ما يلي بواسطة ghaer H <barraq20@gmail.com>:
