Hello everyone,
I was trying to create a very simple Foor loop and I am not getting the outcome that I expected. Previously I got a warning which said “Float is not iterable” and now I get Empty list. All de inputs are Double Object.Types:
there are always severial ways ![]()
start = IN[0]
end = IN[1]
list = IN[2]
OUT = []
for i in list:
if i >= start and i <= end:
OUT.append(i)
OUT.Remove(i)
If I copy and paste it, it is not working for me ![]()
Despite existing several ways to do it, what did I do wrong?
the scond one is a codeblock,
and the first one should work
is your object type double or float ?
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
start = IN[0]
end = IN[1]
list = IN[2]
OUT = []
for i in list:
OUT.append(i)
OUT.Remove(i)
The issue is that your start and end values are a list. You need to reduce them to a single item to compare.
you can not always use python one to one, you can varify the code:
import sys
start = IN[0]
end = IN[1]
list = IN[2]
OUT = []
for i in list:
OUT.append(True)
OUT.Remove(False)
ahhhh ![]()
this way
it is item vs list… … i search for a item not a list!
Thank you @Nick_Boyts for your explanation and this workaround. I will keep those functions in my mind for future samples.
However, I did something that it worked for me but I am quite sure it is not Python good practice:
It’s the most straight forward workaround. I’d recommend reducing the input structure outside the python code though, just so it’s more clear what’s happening. It’s better practice (in my mind) to make the inputs match your workflow rather than making the workflow match your inputs in this case.
