Float is not iterable
Hello Dynamo Friends,
I want to do something like this:
	for x in xList:
		if x>=0 and x<=180:
			do something
			do something else
But I`m getting a “Float is not iterable” error.
Can someone please light me up on how to do this?
Kind Regards :slight_smile:
Your code is expecting a list when you’re providing a single float.
Hi @gerhard.p ,
Is there a specific reason you are doing this in Python? With some simple DesignScript you can also achieve this, just plot this code into a Code Block:
x >= 0 && x <= 180 ? x+180 : x ;
where as: query ? true : false ;
I need this for a larger python script :slight_smile:
So why does this work with a single float:
NumberList = range (5,60,8)
resultList = []
for x in NumberList:
	if x<30:
		result = "Potato"
		result = "Tomato"
	resultList.append(result)
OUT = resultList
What do you mean? That code does exactly what you’d expect. Each number in NumberList returns Potato if <30 or Tomato if not. What were you expecting as the output?
Yes, i was wondering why this test code works but my other code not.
I´m sorry it seems that it was just a list level problem, it works now. Had to add a list level to the angles.
for grids, angles, view in zip(gridList, angleList, viewList):
	for grid, angle in zip(grids, angles):
		if angle<90 and angle>45:
			grid.ShowBubbleInView(DatumEnds.End1,view)
			grid.HideBubbleInView(DatumEnds.End0,view)
			grid.ShowBubbleInView(DatumEnds.End0,view)
			grid.HideBubbleInView(DatumEnds.End1,view)
a small trick :slightly_smiling_face:
if 45 < angle < 90:
