Problem when iterating through lists of different size and levels in python
I have two lists of diferent sizes and diferent amount of levels.
I need to iterate both lists but i keep getting error messages
L1 has level 1 and 2
L2 has level 1, 2 and 3
i need to create a list that returns for me the value of L2 at level 2 that is the first one bigger than the value of L1
This is the code
L1 = [1.69, 18.75]
L2 = [[17.5, 24, 32, 41, 57, 76, 101, 125, 151, 192, 232, 269, 309, 353, 415, 477, 571, 656, 758, 881, 1012],[17.5, 24, 32, 41, 57, 76, 101, 125, 151, 192, 232, 269, 309, 353, 415, 477, 571, 656, 758, 881, 1012]]
res =
for i, j in L1,L2:
	for num in j:
		if i <= num:
			res.append(num)
			break
OUT = res
This is the error message:
File “”, line 10, in
TypeError: iteration over non-sequence of type float
Thank you all in advance for your help!
Maybe with function zip :
L1 = [1.69, 18.75]
res = []
for i, j in zip(L1,L2):
	for num in j:
		if i <= num:
			res.append(num)
			break
OUT = res
The result seems correct.
result
It solved the problem.
Thank you.
But how exactly does the zip function works?
You’re welcome.
The python documentation will explain you better than me how it works.
https://www.programiz.com/python-programming/methods/built-in/zip
I use very often the zip() function in the customs nodes of my package.
