Hi Dynamo community,
I’ve just started creating a script to generate door numbers in order, but I’m having trouble finding the right nodes. Any help would be greatly appreciated. If anyone has a Dynamo script for creating door numbers, please share.
Hi @md.fiyaz, check out this example of door renumbering.
Renumbering door by line.dyn (76.9 KB)
I would suggest that you post your work and show where you are stuck instead of simply using or copy other peoples .dyn so you can learn. Just my thoughts.
