Does RayBounce.ByOriginDirection work with Revit Linked Files?
Hi there,
Does anyone know how to make this node work when there are Revit Linked files in the model?
I cannot make this node work when there are Revit Linked files, it seems the node does not get the geometry from files which are linked.
Any workaround, thought or solutions?
Thank you very much.
The third search result wielded these two links:
Probably a more demanding workflow, but I guess you can also try out the raytracer in the Acoustamo package. It works with surfaces if you’re able to extract that from your linked geomtery.
Hi there,
Thank you both for the answer.
