Guys, I created a routine to change family names in Revit, and then generate an Excel spreadsheet with the before and after names. On my computer, the routine worked normally, changing all the names and generating the spreadsheet. However, on another computer with the same template and the same routine, an error is given that is not described, generating the spreadsheet with the before and after names but not changing the names in Revit. Does anyone have any idea what this could be? The spreadsheet is changed, there is no error in the routine, it just does not change and this error appears;
This error only occurs in Revit; A serious error has occurred. It is recommended to save the work as a new file before continuing.
