What’s up friends?
I was delivering my projects in Revit and they asked me to be able to view the elevations of the contour lines and other details. In my case I use linked projects for which the label contours window is disabled.
Would there be a way to fulfill what you are requesting?
Determine what your process in Revit would be. Then automate it.
This sounds like you’d need a view template with the correct visibility settings applied. Then you could automate the application of that view template to the views that need to show the contour information.
