I’ve got a graph which tags rooms in linked files in plan, however when shifting into section, the z value of the transform isn’t translating for some reason? It means that all the tags end up at 0 height.
If you turn off the view crop after running, Revit prompts you to move the tags and they then pop back to the centre of the rooms, so all is well.
I’d be grateful of any ideas.
Cheers,
Mark
RoomTagDropped-plans.dyn (21.1 KB)
