Disable "show annotation categories in this view" check box
I am working on a script manipulating viewports and view titles. The annotation such as grids and levels make calculating certain center locations difficult and produces undesired results. To combat this I can uncheck the “show annotation categories in this view” and then run the dynamo scrips and everything works. I would like to build that step into the my graph but I can not find a way to uncheck that setting.
This is just a property of the view.
@dmillerSNYXQ just replace the property mentioned by @Nick_Boyts in the following script:
Thank you, @Nick_Boyts and @Elie.Trad, for the help. I am not sure how to select both of you for providing the solution; it seems I can only choose one post as the solution.
I think this is a read-only thing but not able to set yes/no “Show annotation categories in the view” ?
It’s a get/set parameter so it should work. Pretty sure I’ve used it in the past.
Is there a view template assigned to the view that you are trying to modify? This could control whether or not you can check/uncheck for the particular view. (You should be able to check in the Visibility Graphics Dialog)
Hi, I tried but I just saw relevant remark from Mr. Joe.Charpentier
reponse 04 01 2024
I leave script just in case
import sys
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import View
view_source=UnwrapElement(IN[0])
bool=IN[1]
if bool:
    view_source.AreAnnotationCategoriesHidden=bool
    message='Annotation Category is hide'
    message='Annotation Category is active'
OUT = message
sincerely
christian.stan
