Setting view AreAnnotationCategoriesHidden property
As found on the Apidocs:
The following code does not return an error but doesn’t change the property as expected.
It has to be possible to change the property as shown in the apidocs: “set” but i havn’t figured out how.
Using C# it’s as easy as = true, but using dynamo and python this seems a bit harder…
credits: Serhan_BAKIR
If you have an idea on how to access the property and how to set it, please respond.
Kind regards,
Timo Walraven
Hi, im not sure where you have a mistake in the code, so try this one:
curview = uidoc.ActiveGraphicalView
curview.AreAnnotationCategoriesHidden = True
OUT = 0
It works perfectly! I thought I tried this one at first but apparently not. Stupid mistake…
Thank you!
