Change Display Model - View Properties
I have some sections views that I want to turn off the “Display Model” properties, so it will only show annotations. Is there a node that can do that?
An alternative would be changing this setting on the view template, but I couldn’t find a node to do that either!
Look for the View.SetCategoryVisibility node and search the forum you’ll probably find what you need.
Hello @bran0169
try this
import sys
import System
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstView = toList(UnwrapElement(IN[0]))
for v in lstView:
	paraDMode = v.get_Parameter(BuiltInParameter.VIEW_MODEL_DISPLAY_MODE)
	#0 -> Normal
	#1 -> half tone
	#2 -> do not display
	paraDMode.Set(2)
OUT = lstView
Great! Thanks @c.poupin it works perfectly
