I can’t get Direct Shape Objects (Geometry based on a plane) to display a material. Is this a bug or am I doing something wrong? I’m not getting an error and it works in 0.9.2.
Here is my original post:
Hi Jay
Try reporting your issue here https://github.com/DynamoDS/Dynamo/issues/
Sure, here you go.DIRECTSHAPE BUG.dyn (9.0 KB)
The forum won’t let me upload the rvt, says it’s too big (3mb). Just start with a 2017 metric architectural template and make a material called ‘PROPERTYLINES’ (set the shade colour to red). Also make the Revit Property Lines by Sketching. Then run the script in v1.
If it is working you should get red direct shape objects extruded from the property lines.
Thanks for looking into this!
Thank, I’ve made a GitHub issue here: https://github.com/DynamoDS/DynamoRevit/issues/1004
