Direct Shape not working-Revit 2022
I have a simple script which extrudes a shape along model lines. The output is a directshape. This works well in 2021 and previous, but the same graph in 2022 either shows ‘null’ outputs from 3rd party nodes or errors out w/ the OOTB node. Does anybody know what the problem could be?
OK—I figured it out. I needed to update Archi-Lab. While it works in 2022 now, the same file won’t even open in 2021. Is it common to have different scripts for different versions of Revit?
You will need a different Archi-Lab package for each version of Revit. My advice is a different library of packages and a different library of graphs (save as, test, update) for each Revit release.
