Dimensions Grids to Fittings
Hi All
I’m trying to put dimmensioners on my fittings using Dynamo. My scrip works, but only some of my fittings get dimming.
What am I overlooking?
Etc. Jacob.
For fitting try origin reference and not familyinstance reference
Thanks for the quick reply Sovitek.
I’m next in line. It finds the lines but does not apply dimensions.
allright try disconnect your dimtype…keep it empty…or feed in a family dimension type
It doesn’t really work. Maybe I’m misunderstanding you.
I still only get the blue line
As you probably know, English is not my first language.
whats happend when you keep it empty…btw which revit verion are you in ? høhøh Jacob hvis jeg tror hvem du er nu jeg ser navnet :wink: :wink:
Do you mean dimensionType should be empty.
I am in Revit 2022.1
Dynamo Core 2.12.1.8246
Dynamo Revit 2.12.1.11123
Jeg er lige præcis ham slight_smile:
så fedt :wink: :wink:
PS
YES empty no feeding in there :wink: and see i f works
nothing happens
is it latest genius loci package ?
Genius Loci 2023.7.13
hmmm…try update to the latest
PS try pull onto plane
Update to 2024 - Here’s how it worked.
Fortunately, projects have just been updated :grinning:
Thanks Sovitek
Kan altid regne med dig :+1:
