Dimension Type Parameters
How do I get color and Units Format parameters from dimensions, or any parameter that you need to click the additional popup box in the type properties?
Thanks - Jason
Do I have to filter out the different dimension types first to get the units?
Still looking to get this info, any help would be appreciated
I was able to get and set the color with Builtin Parameter, but it’s just giving me nulls if I try the same for the units format
Thanks @viktor_kuzev - I will read up on the API help file and see if I can get and info for the Units format of the dimension.
–>http://www.revitapidocs.com/2017.1/fb011c91-be7e-f737-28c7-3f1e1917a0e0.htm
Adding this to Rhythm now.
Thanks John, This works in 2017!
@Jason_Trahan It works only at 2017.1 or Greater Version. “DimensionType.GetUnitsFormatOptions()” was added in 2017.1 Version.
