i am trying to place the dimensions of an assembly.
I have gotten to the part that dynamo is telling me he placed a dimension.
But there is no dimension in the view. If i look it up by idea it is selected, but no where to be seen… He can’t find a view.
So there is something wrong but what.
Dimension.assembly.dyn (139.7 KB)
i get the element from the active view and i am placing in the active view
Very simple perhaps; but have you checked the visibility options of the annotations?
The fact that is placed suggests nothing is wrong with Dynamo right?
yes you should think, but if i do a normal dimension then it just shows… so visibility and filters and things like that are oke
Maybe the workset that was used is not visible in view? or maybe it is placed outside of the crop region?
Cant you click the element ID to show it in revit?
it cn’t find a good view… i will investigate further
Hi @Arno_De_Lange Even also facing the same issue. Have you found any solution for this ?
have you found the solution yet?
