Hi all,
I like the “Document.BackgroundOpen” and “Document.Close” nodes of the Rhythm package very much.
Unfortunately the “Document.BackgroundOpen” node only takes a filePath as input.
I would like if it could open a selection of families (from the project invironment).
I hope @john_pierson (or others) have similar nodes that can do this (but i am not aware of).
Thanks in advance,
Mark
what are you hoping to do with families from the project then? I’m not sure I understand what you are hoping to do.
Hi @Tom_Kunsman,
I would like to add shared parameters to the selected families, like the below workflow (but then for the families that are already in the project).
https://forum.dynamobim.com/t/node-to-perform-load-into-project-action/14812/10
I hope that makes sence.
Kind regards,
Mark
@MJB-online
I havent seen your parameters, but i use them this way.
If your Shared Parameters do not control Geometry or Materials, add the Shared Parameters to the Project Parameters and assign the Categories.
Marcel
Why not export them to a library and use the current workflow?
Hi @MJB-online, you can obtain the family document via the “DocumentUtilities.GetFamilyDocument” node from Beaker.
Hi all,
Thank you, for your answers.
@Marcel_Rijsmus
Thats a smart workaround, i’ll definitely keep that in mind
@jacob.small
That is also possible, but for now i’m just exploring the possibilities
@john_pierson
Is the action of the “GetFamilyDocument” node, the same as the “Document.BackgroundOpen” node ?
Kind regards,
Mark
Yeah, it is basically loaded the family document into background memory
Hi @john_pierson,
This is the node i was looking for, thanks a lot.
And it’s fast (like lightning) as you mentioned on your blog
Kind regards,
Mark
