Different Area value between Revit and Dynamo
Hello to all the community
I have been working on putting together some tables of data obtained from model geometry, among these data is the area, however I am having a problem obtaining the area of ​​a geometry, since between Revit and Dynamo the values ​​are different, the value of area of ​​the geometry is calculated between width and length of the element
any idea what could be happening?
Give your parameter a different name.
There is probably a built-in parameter “Area” that likely takes the area of the whole solid.
It worked perfectly, thank you very much!
