Diagrid Attractor Points
Hi, I would like to ask for advise. I’m doing a pattern for fritted glass in dynamo.
It contains circles that varies in size in a diagrid pattern.
What would be the best way to go about it? I’m still new to Dynamo and I have only managed to
do circles on a rectangular grid.
This is the area where it is to be applied.
Hi @jancuales ,
could you show an image describing the disired result ?
High @Mostafa_El_Ayoubi something like this but more refined. Thanks a lot!
you can start from here : http://dynamoprimer.com/en/02_Hello-Dynamo/2-6_the_quick_start_guide.html
Thank you @Mohammadz, I went through that a few weeks back. I’m kind of stuck where the grid needs to be triangular unlike the rectangular grid from the example. What would be the best way to filter the points to produce the result as shown in the image
This should get you started :
radius variation by distance to curve.dyn (20.2 KB)
wow thanks a lot! I’ll show you the site pictures when it is done!
