DetailLine.FromCurve isn't working - Clockwork
Hi All,
I’m trying to use the DetailLine.FromCurve of the Clockwork package, and I it says that my Dynamo version (1.2.1.3083) isn’t compatible with some of its nodes.
Please, some help.
Thanks in advance.
It looks as if your package needs to be updated. Update the package and try again. I believe that if you’re trying to open an older script you’ll have to open the file in an older version of dynamo first.
This. Also make sure you don;'t download any other packages that rely on an old version of this node. There are a few out there.
Hi @john_pierson, for example whick packages?
I have these:
Also, I’m working in Revit 2016.
I think you need to remove turn into list and clockwork. Then reinstall clockwork
you nailded it! Thanks a lot!
