Is there a way to set design a option in a view? I’ve seen one node but it only sets the “Visible in Option” parameter, I wish to set the actual design option to edit rather just view it. Is this possible? I have the graph set up already to duplicate the views, append the name of the design option to the view, just need to set it! Thanks,
Found a different workflow!
I believe the workflow I came up with was manually creating view templates that had the appropriate design option set, and used Dynamo to set the view template to the view.
Thanks,
